-   -   !!! UDF - Compilation problem !!! (http://www.cfd-online.com/Forums/fluent/50261-udf-compilation-problem.html)
Everest January 11, 2009 09:38
Hi guys!
I've got problem with compilation of my *.udf. Namely, after trying to LOAD my file i get following error:
Opening library "libudf"... Error: open_udf_library: The system cannot find the file specified.
Actually the problem has been already mentioned: http://www.cfd-online.com/Forum/flue...cgi/read/20789
however neither of the suggested solutions helped. This is what I've already done:
- I got installed MS Visual C++ 2005 together with MSDN library. I also got Microsoft.NET Framework 2.0 SP2 (These two based on: http://www.cfd-online.com/Forum/flue...cgi?read=47472)
- I have also run vcvarsall.bat from the command prompt of MSVC as suggested in http://www.cfd-online.com/Forum/fluent.cgi?read=62748
- I also tried to run Fluent from above mentioned command prompt
- I tried to interpret the *.udf with succes, as I read it suggests problem with the compilator
And still the same problem. I am hopeless. Please help me guys.
Kind regards, Lukas
Davy January 12, 2009 18:56
Re: !!! UDF - Compilation problem !!!
You'd better start to run Flunet from MS Visual Studio Command Prompt and type Fluent to run. The compiler environment will be automatically configured then.
