Parallel partion lines on grid
I'm using parallel Fluent 6.3 in Windows with MSW driver. At the start, it does not show the partions on the grid, which is good. But when I plot a contour, the partion lines show up, which is not good. Clicking the partion box in the grid menu shows the whole partion, unclicking it doesn't make the lines on the walls go away.
My workaround is to load the cases into the serial version for post-processing. Does anyone else have a solution for this? |
Re: Parallel partion lines on grid
for me, serial solver is the only solution
