Importing files to GAMBIT
Old   January 15, 2009, 14:29
Default Importing files to GAMBIT
Carlos Ruiz
I have an AUTOCAD file, and I want to work with it in GAMBIT. I`m having big problems with the importation. What`s the best way to import files to GAMBIT???????
Old   January 16, 2009, 00:23
Default Re: Importing files to GAMBIT
mAx
step file is ok (there are other good format)
in your case, I assume you only have the possiblity to export *.dwg in *.iges
You may import iges file into gambit, but the quality shouldn t be as good as the other.
Clean Up options will be helpfull
Old   January 16, 2009, 12:29
Iván
Hola Carlos,
hablas español?, si es asi te puedo dar bueno informacion para solucionar tu problema, ya que me paso algo similar y pude arreglarlo.
Saludos
Importing IGES files into GAMBIT and meshing kartik FLUENT 3 September 23, 2008 00:12
Importing Gambit files into CFX CF CFX 8 September 25, 2006 02:14
Importing autocad files into GAMBIT Shanti FLUENT 3 June 6, 2006 06:07
Importing files from Pro/E to Gambit Kiran FLUENT 3 October 5, 2004 16:00
importing gambit files into cfx sivakumar FLUENT 3 October 15, 2001 10:09
