January 8, 2009, 19:21 |
Source term
Can some one write a UDF code. its very basic. all i need to do is apply a fixed temperature of 1400K in an axisymmetric problem. i have drawn it in 2d format. please plseas Help me with it. Thank you for your help |
January 8, 2009, 19:37 |
Re: Source term
January 8, 2009, 21:55 |
Re: Source term
If the temperature is fixed, can't you use the wall boundary condition and specify a fixed temp? or you can use the fixed values option in your region of interest.
January 17, 2009, 18:44 |
Re: natural convection on wavy curve surface
Hi friends, I am doing simulation of natural convection on 2D wavy curve surface. Please please help me in clearly certain doubts: I am using realisable k-epsilon model 1)The Grash-off number is of 10^9 order ....... can i use turbulent model for this buoyancy convection 2)In define -operating condition - one unchecked block for operating density is there , I am using INCOMPRESSIBLE IDEAL GAS,do i need to check the operatind density box or leave it 3)1)the continuity equation in not converging (over 6000 iterations), which under relaxation factors I need to alter ,should I decrease or increase the under relaxation factors plz tell exactly or atleast their combinations. PLZ PLZ PLZ HELP.
Display Modes | |
Source term | mayur | FLUENT | 0 | August 10, 2004 14:23 |
Source Term | Prakash Verma | FLUENT | 1 | August 6, 2004 10:56 |
source term | zwdi | FLUENT | 2 | May 26, 2004 11:34 |
the source term | neil | CFX | 10 | July 15, 2002 18:10 |
source term | fouzi | FLUENT | 0 | April 13, 2000 12:56 |
