How can i use Tpoly to obtain Polyhedra?
Dear all,
I want to use tpoly process. But i do not know how to use it and from where? There is a commond like 'utility tpoly input_filename output_filename' but, where will i write this command to? i tried to write it on fluent, it did not work. Can you explain please, how i can use this command? |
Re: How can i use Tpoly to obtain Polyhedra?
If you are using Windows, well DOS, go to the command line and type it in "tpoly input output". Of course, all of the files will have to be in the path.
