-   -   Area-weighted or Vertex average ?? (http://www.cfd-online.com/Forums/fluent/50328-area-weighted-vertex-average.html)
Conan January 20, 2009 03:22
If I wanna compute the overall heat transfer coefficient on a solid surface, after convergence, I first define a "Custom Field Functions": heat-flux/(temperature-300),named as local-h. Then in the "surface integral" report, which option is best for obtaining the overall heat transfer coefficient, Area-weighted or Vertex average?
Thanks.
Tushar January 20, 2009 03:42
Re: Area-weighted or Vertex average ??
generally we prefer area weighted, I dont know the exact reason though
Conan January 20, 2009 04:22
but sometimes, the results by vertex averaging are more close to the exp data. The solid surface has constant heat flux BC, if define: heat-flux/(temperature-300), I think the temperature is obtained by vertex averaged, that is interpolated data from adjacented cell values.
I need more helps, Thanks.
Emad January 21, 2009 04:19
Hello Conan Use area weighted average bacuase this fined average Temperature on the wall by using integral. but the vertex average this fined sum on temperature divided by number od node. with best regards
