-   -   Automatic Data Export (ascii format) (http://www.cfd-online.com/Forums/fluent/50333-automatic-data-export-ascii-format.html)
A Kourm January 20, 2009 12:50
hello,
I am solving a 3D unsteady problem and would like to output values of velocity and temperature every 100 timesteps along 3 'slices' of my domain so that I can postprocess the data within a fortran code, I would like the output data files to be in ascii format.
I am aware of the autosave function FLUENT has, but using this, the ouput data file is some strange format, and I dont actually know what the columns of data represent...Any help whatsoever would be very appreciated.
Thank you very much Agi
Emad January 21, 2009 04:28
Re: Automatic Data Export (ascii format)
Hello Agi I have same problem in 3D rectangular duct, Can't using autosave data. you can used File-->Export--> ASCII click the any data you want. With best regards emad
A Kourm January 21, 2009 05:57
thanks emad, but I need to have the export-data function work automatically each 100 timesteps, since I would like to save the time history of my problem (I am running an unsteady problem). With your method I can only save the data from the final timestep..
A Kourm January 21, 2009 08:36
FYI for anyone else that is interested, i found how to do it, you can use the solve-execute command window, and then write the following:
file/export/ filetype filename () yes list-of-scalars q
you need the q at the end to notify fluent that the list of scalars you want outputted is complete.
