Using VOF method
Old   January 30, 2009, 04:18
Default Using VOF method
Nur Hassan
I'am trying to design CFD model using VOF. 2 m height Cylindrical colum with a 0.4 m diameter with full of water and single bubble rises into the liquid column. 2D segregated, unsteady, using axisymetric solver. try to use a grid an estimated 10000 cells, that is to say 100 cells by 100 cells. Bubble size is 5mm which is air bubble. I need help for creating the mesh and defining the boundery conditions. Please any body help me regarding this? Any tutorial related to this? Regards- Nur
Comparing between the Fractional step method and the SIMPLE method ghlee Main CFD Forum 1 April 10, 2012 16:59
Finite volume method vs finite difference method? superfool Main CFD Forum 4 October 21, 2006 14:37
Pressure Correction method, Finite Volume Method Seeker01 Main CFD Forum 2 January 13, 2003 02:49
hess-smith method and fvm method yangqing FLUENT 0 March 20, 2002 19:25
Projection method and Block-off method Leo Main CFD Forum 0 June 14, 2001 07:22
