problems with residuals in fluent.
Old   February 9, 2009, 07:42
Default problems with residuals in fluent.
Tan
Hi
I am having problems with my residuals in fluent. Tmy velocities and energy lines are both dropping to 1e-06 but my k , epsiolon and most important contuinity are not dropping below 1e-03??
i am modelling a simple closed cavity in a pipe. my inlet for the pipe has - a massflow = 0.305kg/s - turbulence intensity=5% - length scale=61mm (diamater of my pipe) - temp 291k
outlet;
-gauge pressure of 0 -turbulence intensity=0.01 -length scale=61mm
i have messed around with my mesh to make it finer where i have seen high velocity or turbulence values but no matter how fine i make it i cannot get the residuals to drop??
i am using a p-v coupling= coupled with standard default values
canyone help or suggest anything?
thanks in advance
Tan
Old   February 9, 2009, 08:30
Default Re: problems with residuals in fluent.
mange
Are you sure that your fields are not converged? if you disregard the residuals and look at your flow field variables
If you have been doing adaptive refining. I would suggest that you re-mesh your domain in your preprocessor. There you can control your resolution and hopefully get a good quality mesh.
otherwise try p-v coupling = simple.
have fun!
Old   February 9, 2009, 08:46
tan
hi
yeah my flow walues seem to converge i.e.x,y,z velocities and my mass flow is conserved alongside my temp.
but its this contuinuituy k and epsilon value which is hovering around 1e-03 .
i ahve been refining my model manually in gambit not used any auto adaption?
tried p-v coupling =simple initially but i get error; divergence detected in AMG solver: pressure correction
help!
Old   February 10, 2009, 10:05
tan
hi
me again! sorry
i have tried using a turbulencevalues
turb ke =24 turbulence disspaption rate =4524
still no luck on k, eps and contuinuity converging?
Problems with residuals Martin CFX 2 January 2, 2007 22:10
The residuals in FLUENT summer FLUENT 2 June 28, 2006 09:31
fluent: residuals Madhukar Rapaka FLUENT 1 October 14, 2005 10:28
about residuals in fluent Devy FLUENT 5 June 10, 2001 23:50
Problems with residuals?? Peter Kolb FLUENT 0 November 29, 2000 03:48
