Numerical simulation of Supersonic Combustion
Hi all,
im working on simulation of a pipe flow with an orifice with supersonic flow with one end closed and the other end open. The flow near the inlet is patched to 2000 k and i am looking for the propogation of flame front to the open end. The fluid is taken as H2-O2 mixture at stiochiometric ratio, turbulence model as K-epsilon. the problem im facing is the temperature is going beyond 6000k and the arrhenious rate of reaction in orders of magnitude can someone suggest me where i would have gone wrong regards sarath |
Hello
So i am curious about that ,are you use the pressure based solver
