UDF compiling problem in Flient 6.3
Hi all
I have been trying to compile a udf in Fluent 6.3. but an error message is been displayed 1 file(s) copied. (system "copy C:\PROGRA~2\FLU\Fluent.Inc\fluent6.3.26\src\makefi le_nt.udf libudf-EB\win64\2ddp\makefile") 1 file(s) copied. (chdir "libudf-EB")() (chdir "win64\2ddp")() 'nmake' is not recognized as an internal or external command, operable program or batch file. 'nmake' is not recognized as an internal or external command, operable program or batch file. Done. "C:/Documents and Settings/Administrator" Opening library "libudf-EB"... Error: open_udf_library: The system cannot find the file specified. Error Object: () I dont know what is the problem. i loaded the case file and tred to compile the udf, dut the error was displayed. This UDF worked proprly with Linux os, I installed the visual studio 2005. for the C++ compiler , but the same error is displayed. If is there any other way to compile, please tell me. I need the solution very badly since without compiling the udf i cant move furthur in the project. If you want i can send the case and the udf file if you can give me your email id. Hoping for an reply Thank you And regards |
Re: UDF compiling problem in Flient 6.3
PLS DO SEND THE CASE AND UDF TO MY EMAIL ID cfd@pricoltech.co.in
try with MS Visual studio 6 or later editions
