February 24, 2009, 09:29 |
weirdo mole frac profile
I simulate a reforming reaction (endothermic) in a tubular micro reactor (L=30 cm D=1.3 mm). when I contour H2 mol or mass fraciton along the tube length, H2 frac is increasing through the first 2 cm then it starts to decrease abnormally...why this happens?
this is a wall reaction (zero thickness wall)and this is a irreversible rxn. material of construction is Al. there is no problem with volume rxn or non-zero wall thickness when they are tried. C8H18+ 8H2O- 8CO+17H2 thanks in advance |
February 25, 2009, 01:55 |
Re: weirdo mole frac profile
problem may be with incorrect representation of reaction. how the Reaction Rate contour look like. Try plotting Reaction rate along the wall. It can give some clue. how H2 Concentration contour looks.
weirdo mole frac profile | k.alp | FLUENT | 0 | March 14, 2009 17:07 |
UDF solution variable for time-averaged mass frac? | A. S. | FLUENT | 0 | May 14, 2007 16:44 |
Pressure outflow w/ species; mass frac. required? | Myth | FLUENT | 2 | September 29, 2006 23:08 |
How to get mole fraction | shuqin | FLUENT | 2 | March 6, 2006 08:37 |
increaseing vol frac after x iterations | Rashmi | FLUENT | 0 | December 13, 2005 21:28 |
