Coal Devolatilisation
Old   February 24, 2009, 20:44
Default Coal Devolatilisation
James Macphee
Firstly thankyou to anyone that responds to my question. Your help is greatly appreciated.
My question relates to the two competing rates devolatilisation model. I am modelling pulverised coal fired through an swirling burner into a furnace. I have information on the proximate and ultimate analysis and high temperature volatile yield of the coal.
I am using the two mixture fraction/PDF approach and defining the volatiles as the emperical secondary stream. When I set values for the mass fraction of each element should I take into consideration the high temperature yield or just use the values from the ultimate analysis. From what I understand my coal flame does not necessarily achieve the high temp yield but is probably more than the proximate analysis yield that is found under slow(???) heating conditions. Also should I keep the second weighting factor as 1 or set it to the high temp yield fraction that I know.
Thanks again for any help. I am stuck as to where to go with this.
Coal Devolatilisation James Macphee FLUENT 0 February 24, 2009 20:45
coal combustion jarek CFX 4 November 28, 2007 00:23
Coal Combustion DFS CFX 0 August 28, 2007 04:57
can Star-cd32 solve coal/non-coal particle? Leo Siemens 1 October 25, 2004 15:38
Coal with EBU Magnus CFX 2 September 14, 2001 01:34
