Home > Forums > FLUENT
GAMBIT,can't re-open mesh to modify
Old   February 25, 2009, 00:34
Default GAMBIT,can't re-open mesh to modify
Muntasir
Hi, can sombody tell me how to use GAMBIT to re-open a mesh file that i've created using GAMBIT.
muntasirmahadi@yahoo.com
Old   February 25, 2009, 01:26
Default Re: GAMBIT,can't re-open mesh to modify
sathees kannan
if the file is .msh file, you can't open that file directly in GAMBIT. You have to Import that file. File->Import->Mesh
Old   February 25, 2009, 02:45
Muntasir
Thanks, i've just tried it. Error msg received; The Gambit neutral file header (record 1)is non-standard. My mesh is 2D ,Solver:Fluent 5/6.
Old   February 25, 2009, 03:01
sathees kannan
To solve your problem, do this: - read the .msh file in Fluent - save it as .cas file - read it back into Gambit, importing as Fluent 5/6 .cas 2D file. ##Thanks to Razvan##
Old   February 25, 2009, 03:17
Muntasir
Many thanks, you've solved my problem.
Old   February 25, 2009, 03:18
sathees kannan
you are most welcome
Thread Tools
Trackbacks are On
How to open mesh file in Gambit /pls help FRAJ FLUENT 13 March 2, 2011 09:15
An Open Source mesh generator for Open Foam Ahmed Main CFD Forum 15 September 23, 2010 18:39
Cannot open Gambit? Why? emad FLUENT 10 January 2, 2009 10:11
how to open .cas file in gambit? revathi FLUENT 4 August 16, 2007 01:28
open mesh files in gambit A.Naser FLUENT 3 February 20, 2004 06:39
