Drag over Ahmed body
Old   May 18, 2009, 10:44
Default Drag over Ahmed body
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
Hi all
I am simulating flow over Ahmed body in 2D. I want to calculate four drags front nose , the drag at the slant surface the back, the back drag and the total drag.
I want to ask that do I need to specify different reference area (or depth , I am not sure) for each of the drag values.
If yes, what reference area should I take. Remember that I am doing 2D!
N.B The values are not comparable with the standard graph of Drag coeffcients available for Ahmed body at different back angles!
Regards
Shamoon Jamshed is offline   Reply With Quote
Old   May 18, 2009, 13:02
Ralf Schmidt
Ralf Schmidt is on a distinguished road
Hi!
check this out:
http://www.cfd-online.com/Forums/flu...hmed-body.html
For drag coefficient calculation, have a look inside the Fluent manual, how the area in 2D is calculated.
As far as I know, you have to set the reference area different for every value...
Just set different values and compute the coefficients... and you will see the influence...
Ralf
CFD - nothing but Colourful Fluid Dynamics
Ralf Schmidt is offline   Reply With Quote
Old   May 18, 2009, 15:15
Shamoon Jamshed
Well the mesh is structures. All the results, vel profile, stream lines are correct. The only problem is the area. In 2D I dont know how to specify the area for each individual wall!
Fluent manual didnot help
Can't get good results on ahmed body research Michael Main CFD Forum 8 September 17, 2008 14:55
Drag plot on Car body m@rk@s FLUENT 0 May 13, 2008 15:53
Flow around the ahmed body (large eddy simulation) Benzamia CFX 0 February 26, 2007 06:03
aerodynamic of Ahmed body VORTEX FLUENT 1 August 7, 2006 21:48
3d ahmed body flow Erdem Siemens 5 March 6, 2006 11:05
