Home > Forums > FLUENT
Type of meshing
Old   February 28, 2009, 14:50
Default Type of meshing
Cheung
hi there,
I'm doing a work on flow over a cube using gambit & fluent. Basically, I put a solid cube of 1.25cm in size in the middle of a tunnel of dimension 390x60x5cm (x, y & z respectively). The problem that I have at the moment is getting proper meshes (face and volume meshes) onto my object. I need to have very fine meshing at the region around the cube (infront, sides, top & back of the cube) cause that's where the I'm going to do the analysis from. I have tried using size function but it resulted in either poor quality meshes or errors would appear.
Any advice/guidance would be mostly appreciated.
Thanks
-Cheung
Old   March 2, 2009, 08:23
Default Re: Type of meshing
mange
divide your domain into several smaller sub volumes (rectangular shape). With some patience and luck you can then mesh using hexahedral cells and stretching. Hopefully you can then satisfy the need of small cells at your "area of interest" while keeping cell count at a minimum.
Old   March 3, 2009, 03:33
Nishikant Tamrakar
you can also see this site: http://www.fluent.com/software/sf_me...l_cylinder.htm
this is for flow past cylinder , but you can use the approach for meshing.
Good luck.
Old   March 3, 2009, 14:41
Cheung
What should if I want to reduce or minimise the number of highly skewed elements in my volume mesh?
Thanks -Cheung
Old   March 4, 2009, 06:41
Cheung
Sorry for the typo..
What I meant was -What should I do if I want to reduce or minimise the number of highly skewed elements in my volume mesh?
Thanks -Cheung
Old   March 6, 2009, 00:14
Ganapathy
IF you do proper subdividing of the geometry, you will not get any skewed elements. your inner cube has 6 faces. So divide the domain into 6 parallelepiped's using these faces. The remaining place will be filled by other parallelepiped's
Old   March 6, 2009, 13:22
Cheung
Hi, I'm sorry for asking this.
But can you elaborate more because I don't really understand what you meant. The cube inside the tunnel is resting on the floor of the tunnel, that's just for additional information.
Sorry for the hassle.
Thank you in advance.
Cheung.
Old   March 6, 2009, 13:42
Ganapathy Iyer
Lets say its a 2D case. You can always extend it to 3D. The cube (Square in 2D) will rest on the Floor. The tunnel will be a huge rectangle on which the Square will be resting. So the Square will sub-divide the rectangle into 5 other rectangles. Three of these will be formed by the sides of the Square. The other two will be the rectangles in the empty spaces. After this subdivision, you can control the mesh using a sizing function on the edges and create a beautiful hex mesh.
Thread Tools
Trackbacks are On
Calculating meshing element type Ken FLUENT 0 April 27, 2007 02:10
GAMBIT: Assumption of an edge type while meshing Agnes FLUENT 0 June 22, 2005 13:37
O-type quadrilateral meshing hatta FLUENT 2 February 9, 2004 12:06
O-type meshing hatta FLUENT 0 February 1, 2004 14:16
Meshing by specify a type and number of node Jackie CFX 5 April 13, 2003 16:54
