Unsteady Flow-Time Step Size
Like Tree3Likes
  • 3 Post By R Liew
Old   March 5, 2009, 10:50
Default Unsteady Flow-Time Step Size
Maple
I using unsteady flow option in fluent to solve a non-premixed combustion problem.
I need to define the number of steps and the steps size. The total chamber length is around 250mm and the maximum velocity is around 0.5 cm/s.
Please anyone could tell me what should be the number of steps and the step size, and also the max. number of iteration. How should i calculate them?
Thank you very much.
Old   March 10, 2009, 08:52
Default Re: Unsteady Flow-Time Step Size
R Liew
Hi
The time-step is dependent of the size of the cells. You should take the minimum cellsize in your domain. The timestep is then:
dt = size/speed/4. (courant number around 0.25 with reactions)
this is the maximum dt.
The number of iterations is then: 0.25/0.005/dt.
good luck!
Raoul
g0800276, Mar777 and rajann_786 like this.
Time step size and max iterations per time step pUl| FLUENT 33 October 23, 2020 22:50
SELECTING TIME STEP SIZE, NUMBER OF TIME STEP NITUL KALITA FLUENT 2 November 22, 2012 08:28
Is there a way to write the time step size, time a may FLUENT 6 November 22, 2009 11:52
Time Step Unsteady Sonic/Supersonic Flow Singh Main CFD Forum 3 July 23, 2008 09:38
time step for unsteady turbulent flow vishnu FLUENT 4 December 11, 2006 03:25
