-   -   Parse error (http://www.cfd-online.com/Forums/fluent/50767-parse-error.html)
Vamsee March 4, 2009 14:15
Parse error
Hello friends
While interpreting my UDf I am finding a problem. The Problem says as shown below.
cpp -IC:\Fluent.Inc\fluent6.2.16/src -IC:\Fluent.Inc\fluent6.2.16/cortex/src -IC:\Fluent.Inc\fluent6.2.16/client/src -IC:\Fluent.Inc\fluent6.2.16/multiport/src -I. -DUDFCONFIG_H="<udfconfig.h>" C:\Fluent.Inc tbin tx86\source.c
Error: C:\Fluent.Inc\ntbin\ntx86\source.c: line 33: parse error.
my UDf goes like this
/* UDF for the Energy Source Term */
C_UDMI(c,t,0) - x(hydroegn concentration)
C_UDMI(c,t,1) - dx/dt
C_UDMI(c,t,2) - P_eq
C_UDMI(c,t,3) - k */
#include "udf.h" #include "mem.h" #include "stdio.h"
#define R 8.314 /*Universal Gas Constant- J/mol K */
#define Ea 21170 /* Activation Energy - J/ mol K */
#define xi 0.0 /* Initial Concentration */
#define xf 1 /* Final concentration */
#define dh 28000 /* Enthalpy, J/mol */
#define ds 107.2 /* Entropy - J/mol K */
#define RR 75 /* Reaction Rate - /sec */
#define Na 4 /* Number of atoms/molecule */
#define Mol 400 /* Molecular weight of metal hydride, kg/Kmol */
#define fs 0.35 /* plateau slope factor */
#define fhys 0.12 /* hysterisis factor */
#define Ps 5*e5 /* supply pressure, Pa */
#define Pb 5*e5 /* Bed Pressure,Pa */
#define e 0.5 /* void fraction */
#define Rho 8400 /* density of metal hydride, kg/m3 */
DEFINE_SOURCE(energy_source,c,t,ds,eqn) /* LINE NO:33 */ {
real energy_source;
real time = RP_Get_Real("flow-time");
if(time==0)
C_UDMI(c,t,0) = xi;
C_UDMI(c,t,1) = 0;
energy_source = (1-e)*Rho*dh*500*Na/Mol *C-UDMI(c,t,1);
return energy_source; }
DEFINE_EXECUTE_AT_END(execute-at_end) {
double temp,K,P_eq;
Cell_t c;
Thread *t;
int ID= ; /* Zone ID of Porous Zone */
Domain *domain = Get_Domain(ID);
thread_loop_c(t,domain)
begin_c_loop(c,t)
Temp= C_T(c,t);
P_eq= exp((-dh/(R*Temp))+(ds/R)+fs+fhys);
C_UDMI(c,t,2) = P_eq;
K = RR*((Pb-P_eq)/P_eq)*exp(-Ea/(R*Temp));
C_UDMI(c,t,3)=K;
C_UDMI(c,t,1) = K*((C_UDMI(c,t,0)-xf)/(xi-xf));
c_UDMI(c,t,0) = C_UDMI(c,t,0)+(C_UDMI(c,t,1)*RP_Get_Real("Physical-time-step"));
end_c_loop(c,t)
please help me.
Thanks in advance Vamsee
Vamsee March 5, 2009 00:39
Re: Parse error
hello friends...
anyone please help me in this problem
regards Vamsee
max March 5, 2009 04:42
Re: Parse error
hello Vamsee,
you really should take some time to have a look on both, Fluent's UDF User Guide and maybe some basic C-Programing book. Some things will then be straight forward for you, for example that you must not use something like C_UDMI() outside the body of any Macro (Define_.....)
cheers Max
Vamsee March 5, 2009 05:09
Re: Parse error
Hello Max,
the statement which your talking about are comments just written for my convenience. They are not defined. sh0oludn't I write like that? please help me if there are any more.
max March 5, 2009 06:00
Re: Parse error
Sorry Vamsee,
i was too blind to see. One thing you can try is to compile your udf instaed of using interpreted mode. Maybe the compiler directives "#" are causing the troubles.
cheers Max
