To 'couple' or not to 'couple'...)
Old   March 5, 2009, 11:29
Default To 'couple' or not to 'couple'...)
Freeman
Hi Folks!
I have an easy doubt. I have an air flow at a rate of 90.3m/s (that is M=0.266, still <0.3, so I solve the problem by means of the segregated solver), smashing a 3D rectangular wall. I want to get the pressure distribution over the wall.
But the problem comes when I solve the problem with the segregated solver (convergence in 2nd order QUICK is fine) and I found that in certain locations of the wall, the air goes at a speed of 170m/s, that is M=0.53, which is more than the threshold of 0.3 which shows us if we need to switch to couple solver, due to the flow must to be considered compressible.
The question is: if the mean flow is M<0.3 but in some little locations (corners of the wall) M>0.3, may I use coupled or segregated is still valid??
Thanks to your opinions
Regards,
Freeman
Couple c0384 Siemens 1 December 6, 2007 15:00
COUPLE ERROR star Siemens 3 May 17, 2007 05:19
Couple error Yehia Siemens 3 January 25, 2007 03:58
Couple information raffap Siemens 2 December 21, 2006 02:53
How import couple set Mir Siemens 2 January 12, 2005 02:20
