temperature limited to 1 in only one cell ??!!! |
July 2, 2009, 09:47 |
pipin
Rep Power: 17 |
I've an unsteady problem, coupling fluid and solid domain. After 5s calculation, i've a message ' temperature limited to 1.000 in 1 cell' this cell is between a solid and gaseous zone, but doesn't stop the convergence... In the gaseous zone, i use the DTRM model and k-epsilon with Non equilibrium model. The mesh has a correct skewness (<0.9). Thanks for reply |
July 20, 2009, 07:56 |
pipin
Rep Power: 17 |
I have not managed to solve the problem if someone have solution, I shall be very grateful |
July 20, 2009, 08:32 |
#3 | |
Rep Power: 16 |
You can also go to solve/monitors/limits and change temperature limit. You can also let it be for a couple of iterations and temperature in that cell might stabilize. Good luck |
July 21, 2009, 09:48 |
pipin
Rep Power: 17 |
thanks,
But after many iterations, this problem spreading to other cells whereas it is in a solid that heats slowly and that the mesh quality is good (skewness < 0.9), these cells are adjacent to one side adiabatic. I want to reduce the UDR of energy? What do you think? do you have other ideas? |
July 21, 2009, 10:53 |
Rep Power: 16 |
you can lower the URF, although if the number of cells is going up it will eventually go down and lower URF will only postpone this. If it doesn't start stabilizing and going down than you will have a divergent case. Question is than, what sort of temperature are you suppose to get in this cell and why the limit is so low (1000K)? |
July 21, 2009, 10:58 |
pipin
Rep Power: 17 |
The temperture is lower than 1 and not 1000 K...it's in a zone where the temperature is equal to 293K and heat slowly...
I think i will make again the mesh... |
TEMPERATURE LIMITED problem | emanuele | FLUENT | 9 | June 15, 2018 10:45 |
FvMatrix coefficients | shrina | OpenFOAM Running, Solving & CFD | 10 | October 3, 2013 14:38 |
Temperature limited to 1.00 in 18 cell on zone 4 | MANOJKUMAR | FLUENT | 0 | February 21, 2006 08:06 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
