udf for velocity profile_velocity v(y,t)
Old   March 3, 2009, 14:24
Default udf for velocity profile_velocity v(y,t)
shubham
hi all.. can anyone tell me how to write the udf for velocity inlet in which the velocity increases first then reaches max and then decreases with time and one more thing the flow of the fluid through the inlet is not a full flow i.e the the max level(from horizontal bottom of cylindrical pipe) of fluid at the cylindrical inlet at any time is approx the radius of the pipe means velocity is function of both space and time i.e. v(y,t).... thanks in advance...
Old   March 4, 2009, 07:44
Default Re: udf for velocity profile_velocity v(y,t)
shubham
help me its urgent...
Old   March 10, 2009, 08:54
R Liew
Hi
You should check the UDF manual section 12.1.
It's totally described here.
Good luck!
Raoul
Steady pipe flow mean velocity higher than inlet velocity anita OpenFOAM Running, Solving & CFD 7 September 25, 2012 05:35
Velocity profile as an velocity intlet condition kees FLUENT 3 April 16, 2008 18:35
velocity profile as an velocity inlet condition KEES Main CFD Forum 0 April 15, 2008 11:26
Head loss function of velocity^2 or velocity^1? jrg Main CFD Forum 1 November 19, 2007 13:09
particle velocity and velocity profile HGG FLUENT 2 June 10, 2001 16:32
