March 3, 2009, 14:24 |
udf for velocity profile_velocity v(y,t)
hi all.. can anyone tell me how to write the udf for velocity inlet in which the velocity increases first then reaches max and then decreases with time and one more thing the flow of the fluid through the inlet is not a full flow i.e the the max level(from horizontal bottom of cylindrical pipe) of fluid at the cylindrical inlet at any time is approx the radius of the pipe means velocity is function of both space and time i.e. v(y,t).... thanks in advance...
March 4, 2009, 07:44 |
Re: udf for velocity profile_velocity v(y,t)
help me its urgent...
March 10, 2009, 08:54 |
Hi
You should check the UDF manual section 12.1. It's totally described here. Good luck! Raoul |
Steady pipe flow mean velocity higher than inlet velocity | anita | OpenFOAM Running, Solving & CFD | 7 | September 25, 2012 05:35 |
Velocity profile as an velocity intlet condition | kees | FLUENT | 3 | April 16, 2008 18:35 |
velocity profile as an velocity inlet condition | KEES | Main CFD Forum | 0 | April 15, 2008 11:26 |
Head loss function of velocity^2 or velocity^1? | jrg | Main CFD Forum | 1 | November 19, 2007 13:09 |
particle velocity and velocity profile | HGG | FLUENT | 2 | June 10, 2001 16:32 |
