Fluent simulation problem & Gambit "database"error |
March 10, 2009, 11:57 |
Fluent:
I am running simulations involving a symmetric airplane geometry (only running sim. on half of the plane due to symmetry). I get through about 1500 simulations and look at the results and, on the plane, the only results that appear are near the edges. I am thinking maybe it is a problem with the volume being water tight. Gambit: I haven't tried to load my model for a few months now and got this error when trying to open it: "Error: Unable to read format of database (version 2.4.4). The current format is version 2.3.14." If anyone can help with either of my issues I'd greatly appreciate it. Thanks. - Chase |
March 10, 2009, 12:26 |
Re: Fluent simulation problem & Gambit "database"e
for gambit problem you can try to import the mesh from fluent that means import *.cas file in gambit
March 12, 2009, 09:48 |
Gambit: Sounds like there might be a problem with your Gambit release. Sounds like you made the geometry in a newer version than you currently have... Not sure the fix. Check your with your IT guys on the Gambit version (current release is 2.4.6 from 2007)
Fluent: Sounds like a problem with your setup, need to give us more information. It shouldn't be a water tight problem, or you wouldn't have a volume mesh. Sounds like a boundary condition problem to me. Jason |
February 21, 2013, 04:01 |
gambit .dbs file read error
EZHILMARAN
i m also having the problem of reading gambit(2.3.14) file in gambit 2.2.14 version . i dont have 2.3.14 version so kindly help me
February 21, 2013, 04:15 |
EZHILMARAN
help me to read new version of gambit(i.e 2.3.14) into old(2.2.14)
database dns simulation | giacomo | Main CFD Forum | 0 | September 23, 2008 04:09 |
ERROR in user-defined database materials | Julien Lepaul | FLUENT | 3 | April 16, 2008 09:13 |
How to change the material database for Fluent | sxf | FLUENT | 1 | May 3, 2005 16:37 |
internal database error | pradeep sivakumar | FLUENT | 1 | March 9, 2001 07:53 |
Gambit Journal File Scripts, Public Database Needed? | Jonas Larsson | Main CFD Forum | 13 | March 2, 1999 07:25 |
