March 10, 2009, 12:12 |
AMG solver _divergence detected
Hi guys
I am simulating a problem with 0.3 M mesh size and density based solver with k epsilon model. When I ran 50 iterations the solution diverged displaying the message Divergence detected AMG solver -temperature. Can anybody tell me what to do? Regards |
March 10, 2009, 12:24 |
Re: AMG solver _divergence detected
hey i have suffered from this problem several times if there is some problem in grid,may be you can try to run laminar problem with present grid first, reply if you solve the problem
March 10, 2009, 13:00 |
We cant try to run on laminar because we have to use the turbulence model from the beginning. Its an assignment and we have ad edline on Friday
March 10, 2009, 15:30 |
Stop the calculation at the ~40th step, nad 'Adopt' the grid. Sometimes it helps. Let us know, if it works please.
March 10, 2009, 17:39 |
adapt the grid? but with respect to which gradient?
March 11, 2009, 00:18 |
what i wanted to you was that "c whether grid is fine if it isnt, right laminar model will also fail and you can look into geometry part of it instead of focussing on turbulence model "
March 11, 2009, 07:59 |
First, I would try with temperature, than velocity.
divergence detected in AMG solver !!! | yansheng | FLUENT | 0 | September 27, 2007 11:22 |
divergence detected in AMG solver. | Babu | FLUENT | 3 | March 4, 2005 03:08 |
divergence detected in AMG solver: | Shekhar Jain | FLUENT | 1 | September 18, 2003 09:31 |
HELP! divergence detected in AMG solver | ann | FLUENT | 3 | January 4, 2003 01:27 |
Divergence detected in AMG solver? | varghese | FLUENT | 5 | May 27, 2002 07:50 |
