Polyhedral in parallel
Old   April 2, 2009, 18:32
Default Polyhedral in parallel
diego flores
drdr18 is on a distinguished road
Hi , everybody.
I have seeking information about polyhedral meshes. But I was not find it. Could tell me someone if it is possible generate polyhedral meshes in parallel??? Or what is the best way to generate a big model in polyhedral mesh??
Thank you
drdr18 is offline   Reply With Quote
Old   April 2, 2009, 19:22
panda is on a distinguished road
I think you must generate a tetrahedra mesh first then convert it into a polyhedra mesh, and if the mesh size is very large you may need a large memory size to handle the conversion.
panda is offline   Reply With Quote
Old   April 2, 2009, 20:54
Default Polyhedral Mesh
diego flores
Yes, I know all the process for generating the polyhedral mesh. What I want to know is the process to generate amodel in a parallel way, if it is possible!!!! So , if I have a large model how I can convert it to polyhedral in parallel.
Old   April 2, 2009, 22:58
I don't think Gambit can generate a mesh in a parallel way, but you can try to see if your conversion can be done in Fluent's parallel mode.
Old   April 2, 2009, 23:31
Default Polyhedral mesh
diego flores
I did the tetrahedral mesh in tgrid, after i export the mesh to fluent 6.3.33, and I tried to convert it in a polyhedrical mesh. all above i tried to do it in a parallel way but it does not work, it fails. So in a only processor fluent cannot do it because the memory is out. that is the reason why i'm asking about the converting to polyhedrical mesh in parallel.
Old   April 3, 2009, 17:56
Allan Walsh
Allan Walsh is on a distinguished road
This may not help you, but the Fluent 6.3 polyhedral converter seems to have issues. The one in Fluent 12 beta works better, and was able to convert a mesh that 6.3 couldn't on the same machine.
At least in Win-dos, there are some standalone utilities for working with or converting to polyhedral meshes. Perhaps, your friendly Ansys rep. could help you with those.
Allan Walsh is offline   Reply With Quote
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 22:51
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 06:17
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
parallel mode - small problem? co2 FLUENT 2 June 1, 2004 23:47
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 12:00
