Select Vertex-Average or Area-weighted ?
Old   March 16, 2009, 04:34
Default Select Vertex-Average or Area-weighted ?
gnxie
Conan is on a distinguished road
Send a message via MSN to Conan
Hi, everbody. I have a question about the post-handling results. For example, if I have defined a variable in "Custom Field Funtions" like heat transfer coefficient: h=flux/(Temperature-300), now I wanna check the averaged h on a wall surface. In pannel [Reports-->Surface Integrals], which Report-Type I should select:"Area-weighted " or "Vertex-Average " ? The results by the two types are much different !! i.e., 2000 and 100.
BTW: If I select "Vertex-Average" in Field-Variable [custom-field-function], or, I select "Area-weighted" in Field-Variable[Wall-Flux-->Surf.Heat.Trans.Coeff] , the results are similar. i.e., 100 and 120.
SO, based on these, I think, Vertex-average is best for custom-field-cuntion varibale. Right? or not.
Please give me some suggestions. Thanks
Conan is offline   Reply With Quote
Old   March 16, 2009, 05:58
Default Area-weighted
Ralf Schmidt
Ralf Schmidt is on a distinguished road
Hi!
Vertex-Average gives you the average value related on every vertex. So, if your mesh is not uniform, you end up having over- / underestimated values (e.g. having a high number of cells in regions with high / low values).
So, area weighted average is the best choice!
I
think, the problem in your area-weighted average is, how the area is calculated. If you have a 2D case, the area weighted average might be calculated using the reference area (>report>reference values).
Best wishes!
Ralf
CFD - nothing but Colourful Fluid Dynamics
Ralf Schmidt is offline   Reply With Quote
Old   March 16, 2009, 08:37
gnxie
I would say that before I use "Area-weighted" to calculate"Wall-flux-->surf heat transf coeff.", I have set the area value (>report>reference values). NOTE that: actually, heat transfer coefficient is indenpendent of area !
whatever the area value I set in reference vaules pannel, The result are similar to that by "Vertex-average" for custom field vaiable
why?
Originally Posted by Ralf Schmidt View Post
Hi!
I think, the problem in your area-weighted average is, how the area is calculated. If you have a 2D case, the area weighted average might be calculated using the reference area (>report>reference values).
Best wishes!
Ralf
Average Facet, Surface Vertex or Area-Weighted Emmanuel FLUENT 3 March 27, 2020 10:55
Area weighted or mass weighted average SAM Main CFD Forum 31 April 30, 2018 04:12
Area-weighted or Vertex average ?? Conan FLUENT 3 January 21, 2009 03:19
Area weighted average ashish FLUENT 1 April 12, 2005 18:02
area weighted average Sireesha Pasari FLUENT 1 April 4, 2004 13:06
