volume flow prediction in a fan
Old   March 17, 2009, 10:05
Default volume flow prediction in a fan
nazareno mancinelli
yochule is on a distinguished road
hello, i´m tryng to predict the volume (or mass) flow through a duct with a rotor and stator stage. I have pre designed the geometry of the rotor and stator of the fan. the question is: can i predict the flow rate if i have only the geometry, the rpm (angular velocity)? i fixed the 1 atm and 20°C at inlet. but i dont know what is the pressure gradient or the flow rate. and more important to me is that i don´t know the mass flow that i would have with this geometry configuration. can you help me?
--hola, el problema es que no tengo el caudal o el gradiente de presion a priori y quisiera ver la posiblidad de tener una estimacion de caudal para una geometria (angulos de asiento, cuerdas, perfiles, etc..) y unas rpm determinadas. es posible? solo puedo estimar q la presion a la entrada es la atmosferica y a una temp de alrededor de 20°C y q la salida tambien va a ser a presion atmosferica.
saludos
king regards
yochule is offline   Reply With Quote
blower, fan, flow, rotor, stator
External Flow Prediction around a Car Body S. Main CFD Forum 5 June 5, 2007 22:40
How to set volume fraction in two phase flow Kamel FLUENT 2 March 23, 2007 00:06
How to change from mass flow to volume flow rate stanley FLUENT 1 February 2, 2007 06:44
How to get volume flow rate of a section? Nyquist Siemens 1 September 14, 2003 00:27
Flow + split volume Mark FLUENT 3 March 18, 2003 10:09
