Home > Forums > FLUENT
Little Problem with FluegasDuct Mixer
Old   March 17, 2009, 15:01
Default Little Problem with FluegasDuct Mixer
Andreas Windisch
w00dy85 is on a distinguished road
I want to simulate the Mixing of 2 gases in the gas channel and want to compare which kind of Mixer is better - the Problem is i have hardly any experience in Gambit, if i substract the volume of the Mixer from the duct it doesnīt work, if i only create faces it also doesnīt work - in the tutorials i canīt find any help, and i have no access to the ansys site because i have only a student version - please Help me !!
w00dy85 is offline   Reply With Quote
Old   March 18, 2009, 15:02
Allan Walsh
Allan Walsh is on a distinguished road
Sounds you are getting close to the geometry set-up, what specifically is the problem when you subtract the Mixer?
Allan Walsh is offline   Reply With Quote
Old   March 19, 2009, 04:43
Default Then i get an error, because of a negative volume
Andreas Windisch
and i canīt solve it in Fluent, and the Gas is also going through my mixer !
Old   March 19, 2009, 13:25
Allan Walsh
So, it is a meshing problem that you have. What scheme are using for your volume mesh? My experience is that T-grid is quite robust in giving a mesh that will at least work in Fluent. You have probably already seen that it is one of the options in Gambit. You can convert T-grid tetrahedral meshes to polyhedrals in Fluent, which are more satisfying.
Failing that, you may have to simplify your geometry to make a consistent mesh.
You'll need to be careful if the mixer is part of the domain that the faces between the fluid volume and mixer volume are connected to allow fluid through.
Sometimes it is better just to start with very simple geometry and get the steps down and then move up to your actual case. All of the boundary and internal conditions can be saved so it is not too time consuming to do this. Good Luck.
Thread Tools
Trackbacks are On
Tee mixer Kasper Main CFD Forum 1 August 31, 2007 11:43
Mixer 2D sidgalt OpenFOAM Running, Solving & CFD 1 November 27, 2005 13:51
air mixer in a furnace Sam Salari FLUENT 0 October 14, 2005 12:18
static mixer fish FLUENT 0 January 5, 2005 12:19
Can't see the line in Static Mixer problem. Atit Koonsrisuk CFX 0 December 17, 2002 12:56
