Molecular Viscosity Contour Video
Old   August 22, 2015, 19:03
Default Molecular Viscosity Contour Video
Yetly
yetlyg is on a distinguished road
Dear All,
I am looking to make contour video of molecular viscosity using CFD Post. My study is a transient fluid flow model within a rectangular tube. The computations have been complete and show to have laminar flow, no turbulence.
I tried this approach already: going to Run Calculation>Data File Quantities> Selecting Molecular Viscosity in the additional quantities. I then ran a couple of iterations so that I can refresh CFD post, and activate the desired properties.
From here, CFD Post loads a dynamic viscosity variable. I then tried to create the contour using "dynamic viscosity as the variable". Then I tried to input a min/max value, but my contour is not coming up with any image. The global and local value range is not picking up any values (unknown).
Do I need to run more iterations in order to have some values of viscosity in CFD post?
Any advice is greatly appreciated.
Thank you.
yetlyg is offline   Reply With Quote
Problem with divergence TDK FLUENT 13 December 14, 2018 06:00
Plotting the Viscosity Contour in CFD Post ashtonJ FLUENT 3 June 2, 2015 12:06
Molecular viscosity calculation in LES on OpenFOAM babakflame OpenFOAM 0 January 26, 2014 04:13
Ratio of eddy viscosity to molecular viscosity : Laminar or turbulent flow? JuPa CFX 7 September 9, 2013 07:45
solid particle molecular viscosity setting Tim Guo CFX 3 June 29, 2005 09:26
