March 19, 2009, 09:46 |
Interior BC problem when import into Fluent
oscar
lets say i have a turbine, rect region 1, and rect region 2 (as shown below)..rect region 1 encounter whole turbine and rect region 2 encounter whole things(includes turbine and rect region 1)
I used rect region 1 subtract turbine = volume A then I used rect region 2 suntract A (retain) = volume B then i used volume mesh for A and B i set the faces around the rect region 1 as INTERIOR.. but when i import into Fluent (error such as cannot change to interior becuz there is only one adjecent cell thread) May i know how to solve it? because if i do not to set it as any boundary condition in gambit..it will automatically become WALL in fluent THX |
March 31, 2009, 20:18 |
You may use "interface" instead of "interior", or, you should split region 2 to make sure A and B are connected such that you can define "interior" boundary between them.
April 1, 2009, 01:09 |
Maxime Perelli
Rep Power: 41 |
If Gambit set your faces as wall, it means that they are not connected
I have a doubt about your second substract with retain I would split rect2 with A. clik on plugs-icon, the faces between 2 connected volumes should be pink |
Interior B.C. Problem | Samaneh Zeighami | FLUENT | 6 | September 8, 2012 05:06 |
import STL got problem | fathan | FLOW-3D | 2 | March 10, 2010 17:29 |
Problem of import fluent data to ilight fieldview | seasoul | FLUENT | 3 | September 9, 2008 22:36 |
interior angle problem | Anthony Haroutunian | FLUENT | 0 | March 27, 2008 09:36 |
import on fluent | Valerio | FLUENT | 0 | July 9, 2007 08:10 |
