-   FLUENT (
-   -   how to get temperature gradients (
hari March 20, 2009 09:30
the problem i am working on is flow through a channel with heat flux from one surface. i have solved the steady state and got results. i want to plot the temperature gradient along the axis of the channel. how can i do that?
(when i have checked the derivatives tab it has only pressure gradients.)
pls help me through this.
John March 20, 2009 21:00
Need to manually active by command. Forgot details but you could try to find it by click /solve/set/expert
