March 22, 2009, 12:07 |
help for opening gambit file n Fluent.....
rizwan
hello to all
hope u all fine... i wana open the gambit file in fluent but it gives me the error "null pointer domain error" . i actually completed the second tutorial of the gambit as it is described in the gambit tutorial... but when i tried to open that n fluent it give the above error... plz help n in this regard.... |
March 22, 2009, 22:41 |
Rep Power: 18 |
Are you sure you are using Gambit?
Such problem appears when surfaces normal vectors do not conform with main model axes for triangular grids or in case of rectangular meshes only x and y axes. I do not use Gambit anymore, I think it is not a very good tool. However, it is still possible to have your job done If you are Gambit fan, forgive me, maybe newer versions are better than what it used to be in the past, dunno. Usually "null pointer domain error" appears when you use external (it means not Fluent provided meshers) meshing software. For example your lines or surfaces are defined in wrong directions. If you need more explanation let me know, I will try to elaborate more. Right now check mesh axes alignment with Fluent main axes. Best, Krst |
Gambit and Fluent Help | Vincent Ryan | FLUENT | 2 | January 11, 2009 07:34 |
[OpenFOAM] Paraview command not found | hardy | ParaView | 7 | September 18, 2008 04:59 |
No Fluent menu letters, no libXp.so.6 for Gambit | Gijsbert Wierink | FLUENT | 1 | September 4, 2008 18:10 |
Retrieving files in GAMBIT & FLUENT | Vidya Raja | FLUENT | 0 | November 5, 2005 20:26 |
PHI file structure | Eugene | Phoenics | 9 | November 2, 2001 22:00 |
