Monitor Files Missing
I'm running Fluent 6.3 via batch commands on a supercomputer. I ran a few simulations before I restructured the location of my folders on the supercomputer thus moving my .dat and .cas files to a new location. When I go to run the simulations I get the following error:
Hi Forrest
When you go into the monitor menu then you probably have the path given like "/home/flc/fluent/les_cavity/massflow-in.out" in your case. Its best to take all the paths out and just leave "massflow-in.out". Fluent will then write the monitor files to the directory the *.cas file is in or add data to existing files. That way you can move the files easily between different folders.... regards |
Thanks ODY thats got it!
no worries, my pleasure :-)
