March 23, 2009, 06:02 |
two phase air-water vertical pipe
mohammad hassan
hi all
my problem is a 2m long vertical pipe with 5cm diameter that air injected from a 2.5mm hole bellow the pipe and boundry condition is pressure inlet for water and velocity inlet for air with 1 m/s and pressure outlet for mix at top of the pipe i used eulerian model and unsteady with k-e model for turbulance and bubble diameter of 3 mm.but i cant reach convergency.pleas help me. i need your help soon |
March 23, 2009, 12:07 |
zhao peng
Rep Power: 17 |
the work I do is similar to yours.I think it is better to set air inlet to mass flow inlet.
March 25, 2009, 02:51 |
mohammad hassan
March 25, 2009, 03:53 |
zhao peng
Rep Power: 17 |
Velocity inlet boundary condition is intended for incompressible flows, and its use in compressible flows will lead to a nonphysical result because it allows stagnation conditions to float to any level. You should also be careful not to place a velocity inlet too close to a solid obstruction, since this could cause the inflow stagnation properties to become highly non-uniform. [FLUENT 6.3 User's Guide 7.4]
Mass flow inlet boundary conditions are used in compressible flows to prescribe a mass flow rate at an inlet. It is not necessary to use mass flow inlets in incompressible flows because when density is constant, velocity inlet boundary conditions will fix the mass flow. [FLUENT 6.3 User's Guide 7.2.1] |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
three phase modelling (air sand water ) | Gunjan kumar | FLUENT | 0 | December 29, 2004 07:55 |
Help!!!problems in air jet into water bath | kim | FLUENT | 4 | June 9, 2003 07:04 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
