the contours in Fluent
Old   March 26, 2009, 08:48
Default the contours in Fluent
chaker rym
CHAKER is on a distinguished road
hi evey one,
I want to simulate some parameters that don't exist in Fluent but it deponds on the results of FLuent. Can any body help me.
It's nececssary to use User Define scalars or User define Fonction and how?
I want to get the contours of the mass transfer coefficient end it's deponds on the turbulence dissipaton(given by Fluent)
CHAKER is offline   Reply With Quote
Old   March 26, 2009, 09:46
JP
srjp is on a distinguished road
If your parameter can be calculated from the results, once the simulation is over, you do not need to write UDF or UDS.
You can use the "Custom field function" option of Fluent to create your variable from the existing variables.
"Define" > "Custom field function"
This will open the calculator icon where you can define your own variable as a function of all available variables.
srjp is offline   Reply With Quote
Old   March 26, 2009, 12:00
chaker rym
thanks for your help.
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Contours of density gradient in fluent 5? Ricky Wong FLUENT 3 May 19, 2015 01:39
Anistropic thermal conduction in Fluent 6.2 Bharath FLUENT 0 November 23, 2006 21:07
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 03:27
