March 27, 2009, 05:46 |
DPM issue
Rep Power: 17 |
Hi Guys,
I have the following problem. I should perform a DPM (uncoupled). My flow solution is unsteady. The flow time step is very small and the mesh size is very big (9 million). What kind of particle tracking should I use for my particles? I know that the most correct one is the unsteady one but the particle residence time is around 10-2 that for me means to run kind of 100000 iterations....computationally too much expensive (I should wait months). If I run a steady one I can use only the solution at that timestep. Can I use the mean flow field instead? Thanks for you help, Cinzia |
DPM and LES | R.Sripriya | FLUENT | 6 | April 15, 2017 04:41 |
DPM with UDF - Step-by-Step Procedure???? | Prashanth | FLUENT | 3 | April 3, 2009 17:45 |
DPM - do the particles affect the liquid? | Nikhil Dani | FLUENT | 0 | January 1, 2009 11:58 |
problem about DPM of cyclone separator simulation | jason | FLUENT | 4 | November 12, 2007 03:15 |
slow after mesh for enhanced wall treat DPM | joshkemp | FLUENT | 0 | May 1, 2007 17:20 |
