March 27, 2009, 17:00 |
Fluent Output Data Question
Nicole
Rep Power: 17 |
I have a grid which I have imported into Fluent. I want to export three "tables" of data from my mesh, velocity magnitude at a specified point, instantaneous centerline velocity (along a line of symmetry) and velocity profile of axial velocity at a specified point. Eventually I need to input this data into Matlab. I've tried exporting data in a ASCII format, but it is only returning the data point I've set. How can I extract this information?
Thank you in advance |
March 28, 2009, 06:23 |
Rep Power: 17 |
hello
I'm not sure the answer I'll give you will be efficient , but, by using XY-plot, you can export some datas into text or xls files. For example, I use it to export temperatures along walls. You just have to tick the Box " write to file" in the XY plot panel, and name the file. Don't forget to tick the " order points" , to keep the values ordered by x or y position. Hope it will help you regards |
March 30, 2009, 01:58 |
Rep Power: 18 |
What I understood is, you are able to dump the data into ASCII file but then you need to structure them into specific way, is it right?
March 30, 2009, 19:29 |
Nicole
Rep Power: 17 |
Yes I'm trying to output the data, but that format is only giving me one line of given information. I'm now trying to use a surface monitor at a point, but I can't seem to calculated the axial velocity at a given point.
output |
[OpenFOAM] Output data file on the line of the example | zhoubinwx | ParaView | 0 | February 13, 2008 04:59 |
data output from batch fluent run | Wang | FLUENT | 4 | March 11, 2005 11:01 |
How to get u,v,w velocities from Fluent Data file | Kumar | FLUENT | 2 | November 10, 2004 10:36 |
reading data into fluent | co2 | FLUENT | 0 | December 28, 2003 01:31 |
Question on openning mesh from Fluent | Derek Jing | FLUENT | 5 | April 22, 2002 15:55 |
