April 1, 2009, 11:21 |
Complex problem: Open Channel Flow
Hi guys,
I am modelling (Fluent 6.3) the open channel flow (river flow to the dam). I am interested in steady solution, in the velocity profile near the outputs BC and in the volume flow rates at inflows of turbines (= outputs BC). The domain is 192 x 131 x 9.5 m (x, y, z): http://img5.imageshack.us/img5/1381/geometry.png Well, I cant get a steady solution! And I am trying really hard.. During running I get TVL warning (turbulent viscosity limited to viscosity ratio of 10e5 in ... most of my cells). Solution is a little converged after +/- 50 iterations (reziduals 1e-1) and then turbulence goes up and down and immediately the continuity goes too much up... and crash.. Crashed solution looks like: water level is strongly unbalanced (I can see water in sky BC, i.e. 2 meters above water level) and I can see islands of high velocity in domain routing to sky, in the rest (in horozintal cuts) is zero velocity (even at input BC! (vertical)) I have already tried: a) improving, improving and improving my mesh (I started at 1.6M and ending at 6.2M = top of my computer) b) increase the viscosity of air, 10x - 1000x c) setting up my model differently (more below) d) increase TLV ratio from 10e5 to 10e8 BC: INPUT: a) pressure-inlet direction vector 1,0,0 intensity 5%, diameter 2 m open channel - free surface 199.5 m, bottom 192 m (bottom of the domain), velocity magnitude 0,0818 m/s I tried too: b) mass flow inlet direction vector 1,0,0 intensity 5%, diameter 2 m open channel - free surface 199.5 m, bottom 192 m phase1 (air) mass flow-rate 26 kg/s phase2 (water) mass flow-rate 80,000. kg/s SKY: pressure inlet gauge pressure 0, normal to boundary intensity 5%, diameter 2 m volume fraction of phase2 = 0 OUTPUTS: 2x separated pressure outlets: gauge pressure 0, backflow normal to boundary intensity 5%, diameter 2 m backflow volume fraction of phase2 = 1 (outputs are below water level) WALL: no slip TURBULENCE MODELS: a) realizable k-eps, standard wall function I tried, too: b) RSM OPERATING CONDITIONS: oper. pressure 101325 Pa gravity: 0, 0, -9.81 m2/s specific density 1.225 kg/m3 SOLUTION CONTROLS: I tried: PISO, SIMPLE, Coupled (unsuccesfully - I think because not enough computer power (for 6.2M mesh)) Pressure: PRESTO!, tried too: body force weighted Everything else: 1st order I tried to play with URFs. INITIALIZE: Init: volume fraction of phase2 = 1 k = 2.5e-5 eps = 1.47e-7 x-velocity = 0.0818 m/s then patch: upper region (air region) volume fraction of phase2 = 0 I always check the init before solving VOF set up: using Implicit Body force and Implicit VOF scheme Any ideas? Did anyone have that same problem? Any experiences with VOF and Open Channel Flow? (If you need more info, let me know!) Please help me. I am desperated . I would guess that the problem is in too poor mesh, but I cant make it smoother.. If you think that it is that problem, I will have to make smaller domain.. Thank you very much. (Sorry for my English ) Lett. Last edited by lett; April 1, 2009 at 11:32. Reason: ad. VOF set up |
April 2, 2009, 03:51 |
The convergence problem may be related with your solver selection. I recommend you use SIMPLE with relative low uder-relaxation factors (cannot be too low to achieve a premature convergence).
By the way, have you used the Open Channel boundary condition for the pressure outlet? |
April 2, 2009, 06:51 |
Thank you for your reply!
I tried SIMPLE and I tried low URFs. Open Channel Boundary for the pressure outlet? No I havent. Should I? I wrote that outputs are below water level... So I cant see a reason why to use Open Channel BC instead of ordinary pressure outlet. |
April 2, 2009, 11:09 |
zhao peng
I see your geometry,are you sure that it is a continuous zone,you'd better check this by a single phase flow.
Although VOF model can be used to perform a steady-state calculation,it is usually difficult to get a convergence solution.then you can try to switch to unsteady solver. |
April 2, 2009, 12:24 |
Yes, I am sure that my domain is one continues zone.
If I switch to unsteady solver, it takes too much time.. I tried... (It was running more than 3 weeks and still too far from steady solution) Do you have next idea? Btw. thank you for your answer! |
April 2, 2009, 13:21 |
zhao peng
I don't think it is proper to set gauge pressure to 0 at outlet.There are also two questions.Is the Z-coordinate of bottom 192m in Fluent,because you set the bottom level to 192m.And did you examine the phase distribution after patch ?
April 2, 2009, 19:28 |
I think you should check your outlet boundary conditions again and it seems that the open channel boundary conditions best suit this problem, you may find more details in the Fluent manual about the settings.
April 3, 2009, 03:41 |
2zhaopeng:
About your questions: 1) yes, the Z-coordinate of bottom is 192 m 2) yes, I did examine the phase distribution after patch What value do you suggest for gauge pressure at outlet? I still think that my problem is not in that. 2panda: Why should I use the Open Channel Boundary (OCB) for pressure outlet at the outputs? When I choose OCB I have to set free surface and bottom. And in my case the lowest Z-coordinate of outlet is 192.5 m and the highest is 198.6 m (water is from 192.0 - 199.5). So all of the surface of outlets is covered by water. Second option is to set bottom level and gauge pressure at pressure outlet BC. Thank you both for your time and opinion. |
April 4, 2009, 08:13 |
zhao peng
I think you should define a hydrostatic pressure on outlet,maybe this advice is wrong,you'd better have a try.I still advise you to use unsteady solver,you can reduce the time step size when the interation is stable.
April 5, 2009, 19:51 |
your outlet bc still seems strange to me. is it a pipe-like outlet such that it is alway covered with water? At least, you may have to consider the hydrostatic pressure.
April 6, 2009, 03:36 |
#11 |
Hi, thank you for not giving up :-)
I cant use the unsteady solver, believe me it takes too much time (even with a large time step). 2panda: yes, we can say, it is a pipe-like outlet always covered with water. Right now, I am trying a hydrostatic pressure on outlets. Any suggestions? What value should I use? Should I use UDF for that? I am starting with a constant value of 10.000 Pa. |
April 6, 2009, 06:28 |
#12 |
zhao peng
Hope this UDF can help you,it may need to be modified.
April 6, 2009, 11:11 |
#13 |
zhaopeng, I used your UDF (changed for my conditions), still cant get a converged solution :-(
http://img222.imageshack.us/img222/2338/crash1.png http://img222.imageshack.us/img222/7365/crash2.png Any suggestion? :-( |
April 6, 2009, 22:51 |
#14 |
zhao peng
I review the geometry you uploaded,it seems that the inlet was not seperated to air-inlet and water-inlet,how did you define the phase mass flow-rate in the mass flow inlet boundary?
April 7, 2009, 04:22 |
#15 |
well, for input I have used:
A) pressure inlet and B) mass flow inlet - here: direction vector 1,0,0 intensity 5%, diameter 2 m open channel - free surface 199.5 m, bottom 192 m phase1 (air) mass flow-rate 26 kg/s phase2 (water) mass flow-rate 80,000. kg/s |
April 7, 2009, 04:40 |
#16 |
zhao peng
Did you divide the inlet to two faces and define the boundary separately in Gambit?
April 7, 2009, 08:24 |
#17 |
No, I didnt.
Should I? I dont think its necessary. |
April 9, 2009, 10:56 |
#18 |
Please, is there yet anyone, who have experiences in Open Channel Flow and want to help me?
November 10, 2018, 18:30 |
#19 |
mohammed
open channel flow, tlv |
Outlet condition for open channel flow? | gareth__it_power | OpenFOAM Running, Solving & CFD | 1 | July 17, 2011 03:44 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
open channel VoF flow | Jim | FLUENT | 1 | August 23, 2007 19:47 |
pressure outlet (open channel flow) | Willem Brantegem | Main CFD Forum | 0 | April 3, 2007 09:39 |
Channel Flow reference | Jonas Holdeman | Main CFD Forum | 0 | September 10, 2003 15:49 |
