convergence
Old   April 5, 2009, 08:30
Default convergence
Jin Chen
swe704 is on a distinguished road
I have a problem with convergence.
Form the residual monitor,it seems like all the variables are keeping steady,however form the outlet surface monitor,it more likely the outlet velocity goes up and down and can not tend to be steady up till now(2000 interations)
By the way,i extend exhaust with 1 meter long and choose outflow as BC.
I do hope i can get some suggestions from you.
Thanks!
swe704 is offline   Reply With Quote
Old   April 6, 2009, 00:53
panda is on a distinguished road
you have no need to monitor the outlet surface velocity, it's not accurate in general, however, if your problem is related with the output directly, you have to study which BC is the most suitable.
panda is offline   Reply With Quote
convergence of Euler Equations with WENO Shyam Main CFD Forum 0 June 1, 2007 00:47
Defect correction and convergence ganesh Main CFD Forum 4 June 30, 2006 14:20
Convergence problems Chetan FLUENT 3 April 15, 2004 19:13
Convergence in Flow between corotating disks Felipe FLUENT 7 January 27, 2004 10:20
convergence problem with SIMPLER NURAY KAYAKOL Main CFD Forum 1 February 24, 1999 13:43
