April 5, 2009, 08:48 |
How to adapt region?
hello
i want to define air and water as picture below,but when i go to Adapt region in fluent i can just choose 4 points(a rectangular) to adapt my region,so if i want to define water as picture below what should i do,should i use adapt region two times to define water like this? thanks |
April 5, 2009, 13:09 |
zhao peng
one time is enough,the vertex of rectangular can be located out of the geometry.
April 5, 2009, 13:33 |
it means that water would exist out of my boundaries too,does it cause problems to my solve?(in my problem a wave will travel from left to right)
April 5, 2009, 22:57 |
zhao peng
You can check the water phase distribution by contours of phases after patch,the water will not exist out of the boundaries.
different between adapt and mark region? | fadhil majnis | FLUENT | 0 | November 10, 2008 03:29 |
Gambit HEX core method gives unwanted 2D region | KK | FLUENT | 1 | February 4, 2008 09:31 |
Rotating region of a centr. pump - Counter R wall | Emre | CFX | 0 | September 20, 2007 09:58 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
