Home > Forums > FLUENT
Definition of omega
Old   April 6, 2009, 14:33
Default Definition of omega
jpo
jpo is on a distinguished road
Dear All,
I am modeling a moving, rotating solid inside a fluid volume. The solid has to rotate around an axis which passes through its center of mass. I am using dynamic mesh.
Motion of the solid is done with profile: time, x, y, z, omega_z. I don't use theta_x, theta_y, theta_z because they are always zero and don't change throughout the motion.
My question is: Does FLUENT know that vector omega_z should pass through the center of mass of my solid?
I read 10.6.4 "Solid-Body Kinematics" \Fluent6.2Manual\html\ug\node398.htm
but was unable to understand the definitions of omega.
Appreciate the help.
jpo is offline   Reply With Quote
Old   April 7, 2009, 00:38
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
omega-z = d(theta-z)/dt
If theta-z = 0 in your case, then you don't have any rotation about z-axis.
-mAx- is offline   Reply With Quote
Old   April 7, 2009, 11:03
jpo
mAx,
thank you very much for your answer.
You are talking about rotation of the center of mass. Is this the definition of omega?:
Definition: in solid-body kinematics profile, "omega" is the angular velocity vector of the center of mass. It has components omega_x, omega_y, omega_z.
Your answer seems to match the FLUENT manual, especially Figure 10.6.16. Unfortunately, what I am trying to achieve is a rotation of my solid with respect to an axis that passes through the center of mass. Imagine a football moving through fluid volume, the football rotates as it moves (a spinning ball). Then the center of gravity moves and the axis of rotation moves with it.
From your answer it seems that a spinning ball cannot be modeled with a profile and dynamic mesh. Am I going wrong here?
Old   April 7, 2009, 11:41
-mAx-'s Avatar
Maxime Perelli
6-dof can help you
http://eps.fluent.com/5903/500000762/20060904/6DOF.pdf
Old   April 7, 2009, 15:06
jpo
mAx,
thanks for the link. It got me thinking.
Thread Tools
Trackbacks are On
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
Specific Dissipation Rate (Omega) Lourival FLUENT 2 July 25, 2010 08:59
OpenFOAM14 for Mac OSX Darwin 104 gschaider OpenFOAM Installation 118 July 20, 2008 05:19
Airfoil with k Omega hoochie OpenFOAM Running, Solving & CFD 0 July 3, 2007 08:10
definition of u* for y+<10 Robert Spall FLUENT 0 May 29, 2003 11:40
