negative volume
Old   April 9, 2009, 10:44
Default negative volume
Buddy
zjbwow is on a distinguished road
hi guys
when I tryed to mesh the model in the picture, I always failed with the message "mesh of volume volume.1 contains 1 inverted elements(negative volume)".
I tryed everyway in the Gambit to mesh it and make the interval size smaller but the negative volumes only became more.
and the meshed model can't be checked right by the Fluent.
what should I do
thx in advance
zjbwow is offline   Reply With Quote
Old   April 9, 2009, 22:43
Buddy
and now I've found the negative volume
but what can I do to refine it?
help ,please
Old   April 14, 2009, 03:12
Sathees Kannan
satheeskannan is on a distinguished road
Send a message via Skype™ to satheeskannan
creat geometry in (+X, +Y) direction., Make sure that all your geometry is in positive 'X & Y' direction.
it may resolve your problem.
satheeskannan is offline   Reply With Quote
Old   April 14, 2009, 04:09
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
This trick may be only avalaible for 2d-axisymetric model
Perturb your mesh (with size function for instance) and check if the negative colume remains
-mAx- is offline   Reply With Quote
Old   April 14, 2009, 22:31
Buddy
thx very much you two
I can't wait until these excellent ideas come so that I used the commands splitting volume and setting interfaces.
the problem is solved, pretty good.
Old   April 14, 2009, 22:36
Buddy
I think this method is simple and cool!
Old   April 14, 2009, 22:39
Buddy
hi sir,
can you tell me the method to perturb the mesh?
do I have to use UDFs?
thx
Old   April 15, 2009, 00:46
-mAx-'s Avatar
Maxime Perelli
no UDF, just modify something in your mesh parameter ( or enforce the mesh to be refined somewhere with size-function)
Old   April 15, 2009, 03:57
Buddy
I can find the size-function in the 2-D panel such as MOVE FACE NODES/SPLIT QUAD MESH
but no such functions in 3-D panel
so where's the 3-D size-function? O(∩_∩)O~
thank you again
Old   April 15, 2009, 04:03
-mAx-'s Avatar
Maxime Perelli
size functions are located at the same place (2d-3d)
In operation, click on the right button (the one with the blue tools)
In Tools, this is the second button from the left
Old   April 15, 2009, 04:52
Buddy
why didn't I find these excellent functions before?
thank you so much!
negative element volume (CFX-10.0) CFDworker CFX 8 September 27, 2011 18:16
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
