-   -   How to set the wind tunnel Boundary conditions in Fluent??? (http://www.cfd-online.com/Forums/fluent/63580-how-set-wind-tunnel-boundary-conditions-fluent.html)
Saima April 13, 2009 14:12
Hi ,
I have a problem in which a heater is on leading edge of an airfoil, placed in wind tunnel. Air is inside the tunnel at -5C. And water spray by using atomizer is also there.
This airfoil is placed inside the wind tunnel.I want to setup the boundary conditions. I took,
1. Velocity inlet (bcoz i know the initial velocity which is constant in entire process)
2. Outflow
3. The bottom and top wall (wall with zero shear)
I want to know what could be the boundary conditions for top and bottom walls of Wind tunnel?:confused:
It is very urgent.
Many Many thanks in advance.
Regards,
Saima
raheelrasool April 14, 2009 00:12
You can take them as wall and specify zero as shear value to avoid boundary layer generation there and cross flow across the wall.
Just an idea!!!
Regards,
Raheel
