-   -   Wind turbine simulation help (http://www.cfd-online.com/Forums/fluent/63670-wind-turbine-simulation-help.html)
kirit_GSU April 15, 2009 15:44
1 Attachment(s)
I am trying to simulate 2D savonius rotor wind turbine. but i have done every thing good so far expect the post processing one.
I am trying to calculate the Drag coefficient and Lift coefficient of my work. The way which i am using right now. Report > Forces> then i am going to x and y direction forces. Then converting the the forces in to tangential force and normal force using those two Equation :
Fn= Fx*SinA+Fy*CosA
Ft=-(Fx*CosA-Fy*SinA)
Here is A is 0 for balde1, 120 for blade2, 240 for blade 3 .
After that i am using the formula
Cd=Fd/(1/2*p*U*U*A)
Cl=Fl/(1/2*p*U*U*A)
to calculate drag and lift.
But i am not getting the value which i am suppose to get for this work. Am i going to the right way ??
I have attached jou file i am not sure you will be able to see that please let me know. i cant upload the cas file as the size is more than 97 kB.
thanks in advance
Kirit
kirit_GSU April 16, 2009 10:53
please see the cas file at
http://rcpt.yousendit.com/676477626/...9dd604c4aeb713
with thanks.
sime May 18, 2009 11:10
Hi kirit!
I doing the same problem to u. But i don't know how to Apply the inlet and outlet. How can we apply the angular velocity of rotor what the unknown of turbine problem?
sivarama1 June 23, 2009 06:49
wind turbine rotor
hi all,
i am also doing same problam
please send me your case file and gambit file,i will check it,
kirit_GSU June 23, 2009 10:09
I cant upload file coz its big than they permit. if you give me your mail address i can send it to you
thanks
Kirit
sivarama1 June 24, 2009 06:47
windturbine simulation help
Hi,how are you,
Thankyou very much,
My mail ID:siva@green-line.com,malayathisiva@gmail.com,
sivaramakrishnaiah@live.com
saini.yashwant April 22, 2010 22:45
wind turbine
Originally Posted by sivarama1 (Post 220181)
hi all,
sir i am student of M.tech at NIT surat. i am doing numerical simulation of wind turbine by fluent. so i am facing some problems with defining the boundary conditions. so wl u please help me regarding boundary conditions.sir i have modeled wind turbine in gambit and meshed it with two domain interior domain with .5d same as wind radius. and another one is off bigger domain of 4d in diameter. and 3d in front and 5d in back. i have defined the interface in between the surfaces of interior and outer domain. by giving the condition of rotor stationary and the near by domain air is rotating i am getting the axial velocity at the rotor plane more than inlet velocity. is this correct or not. and please help me out how to calculate the power output and coefficient of power.
thanks
saini.yashwant April 22, 2010 22:48
Originally Posted by sivarama1 (Post 220319)
Hi,how are you,
Thankyou very much,
thanks
sivarama1 April 23, 2010 00:15
wind turbine design
Hi
This is my DESIGN Calculations,but i was done in CFX,i know in little bit in fluent and gambit
http://www.4shared.com/document/Vnjp...dturbine3.html
http://www.4shared.com/document/KaBz..._TURBINE1.html
saini.yashwant April 23, 2010 00:25
sir i hav calculated all this by developing the code for BEMT meathod. but i require the guidence regarding CFD analysis either in fluent or cfx. how to calculate all thins with these softwares
sivarama1 April 23, 2010 04:24
wind turbine
Hi
ok, very long back i was done simulation in CFX-11
Boundary conditions:
Inlet:Stagination Temperature and Velocity(sunsonic)
Outlet: static pressure(subsonic)
K&e model,boundary layer 2mm
