-   -   turbulent viscosity limited to viscosity ratio of? (http://www.cfd-online.com/Forums/fluent/63671-turbulent-viscosity-limited-viscosity-ratio.html)
mechfloeng April 15, 2009 17:10
I'm modeling two-phase mixture, I got error message of:
turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 226857 cells....
Can I get help to solve it?
Thanks
doki April 16, 2009 02:19
that is mainly because of the turbulence model you use.
set the appropriate model, and also better approximation of the turbulence parameters in inlet/outlet boundary conditions.
mbgm9mm5 April 27, 2013 07:09
Madhur Motwani
Hello
I have been also trying to model the flow over rib roughened passages using a realisable k epsilon model.
I am modelling the flow using periodic boundary conditions as i am modelling a flow which is already fully developed.
what should i do in order to specify my inlet turbulent parameters carefully?
I have used intensity and hydraulic diameter of the duct.
any body's help is highly appreciated.
Far April 27, 2013 09:53
is it affecting your solution convergence...
Can you show us pics of mesh please?
Please also post some pics of residuals...
itsme_kit February 6, 2014 13:45
Hi
I got this problem too
However, my convergence seems to be fine
Only the turbulent viscosity is the problem I faced
If velocity is not my interest of research, could I just leave it without further fix?
Cause I only care about temperature field
Hopefully you can help me a little
Thanks
