Meshing tank with two opposite inlet/outlet with cooper |
April 20, 2009, 09:03 |
Rep Power: 17 |
Hi everybody,
I am trying to mesh a 3D tank with two opposite inlet and outlets whose axis are not in the same plane. I first mesh the two inlet and outlet (two volumes), then I divide the tank with a brick type split and then try to mesh that brick (see figures), but I get this error message: ERROR: Splitting of existing meshes on a source face (face x) is not implemented yet. Face x is one of the side faces (connected to the inlet/outlet) I try to mesh with cooper element type, but it is not possible. Any advice as to how to do it? I think that the problem arises because the two wource faces (one of them is face x) are meshed. But this should be like this (at least the part of the inlet/outlet should be meshed), so I do not know how to solve this. Thanks in advance |
[GAMBIT] Issues with Cooper Volume Meshing | Forrest | ANSYS Meshing & Geometry | 6 | September 19, 2018 04:07 |
Meshing of a stirred tank reactor | Ajayi Olukayode | FLUENT | 8 | October 3, 2012 02:24 |
Cooper meshing error: intersecting edge | Stuart | FLUENT | 5 | February 26, 2009 06:46 |
Sloshing tank meshing | Fanny | FLOW-3D | 0 | November 25, 2008 04:32 |
IMPRINT COMMAND IN COOPER MESHING SCHEME | TINA | FLUENT | 3 | October 7, 2006 05:03 |
