define a point to trace its unsteady pressure
hi max and all
I can define a point to monitor its unsteady pressure by using the surface-point command in a 2D model.But failed in a 3Dmodel. the error message is ''surface creation failed!''. so what should I do to define a point in the 3D model? thx in advance |
Be sure that the point you defined is in your model.
You can return to gambit, create your point and checking that it's ok. I just created a point in Fluent 3d, and it is ok |
yeah I just tried what you say it works. it turns out that the point you defined should around the nodes or it will fail thank you :) |
