Outflow vs Pressure Outlet BCs
Old   April 27, 2009, 02:30
Default Outflow vs Pressure Outlet BCs
Vivek
visuja is on a distinguished road
Could someone explain to me the difference between outflow and pressure outlet boundary conditions?
I simulated a steady state flow through a straight pipe using the two different boundary conditions at the outlet, with a velocity inlet boundary condition at the inlet. I get quite different results in terms of the total pressure drop. Why is this so?
Thanks,
Vivek
visuja is offline   Reply With Quote
Old   April 27, 2009, 03:58
Hertzel is on a distinguished road
The conditions Fluent uses can be found in the manual
http://www.ipt.ntnu.no/manuals/Fluen...g/main_pre.htm
the outflow boundary condition is described in 7.10.1 and 7.10.2
the Pressure Outlet boundary is described in 7.8.1
taking a quick look at it i think the pressure outlet defines
-static pressure
-backflow condition
(and some other things)
while in the case of an outflow a zero diffusion flux is defined for all variables
Hertzel is offline   Reply With Quote
Collocated SIMPLE and outlet pressure yhoarau Main CFD Forum 1 April 16, 2009 09:16
B.C.S on outflow outlet and pressure outlet kenneth Main CFD Forum 4 May 29, 2008 20:57
Pressure outlet condition can't fix the pressure? mei FLUENT 7 February 6, 2002 21:53
Fluent 5.2, UDF and Pressure BC's Alfonso Ferrandez FLUENT 0 May 4, 2000 07:02
UDF in Fluent to Match Mass Flow at Pressure Outlet Jonas Larsson Main CFD Forum 1 April 29, 1999 10:44
