-   -   Problem with turbulent models (http://www.cfd-online.com/Forums/fluent/64022-problem-turbulent-models.html)
mech5190 April 27, 2009 10:49
I have made a model of hydrofoil and i try to run Fluent. I use SIMPLE algorithm and my problem is that run right only with allmaras turbulent model. Why dont it run with other turbulent model?? Must i change something (example: under relaxation factors?? and how??) . I note that i have use boundary layer with first line 3e-06 lenght, in Gambit.
vishyaroon April 27, 2009 14:18
Can you be more specific as to what problems you have with the other models? Is it a problem with running or with the results you get?
As a side note, for external flows SA turbulence model works well as compared to other turbulence models.
mech5190 April 27, 2009 15:44
yes, i will explain you. With other turbulent model i dont take a logical results. I don have issue for no conergence but for results.
For example i run my model with allmara and after 300-400 iterations with SIMPLE and default under relaxation factors, i take a good results (right distribution of pressures) and convergence. However, when i put k-w turbulent model, i dont take something logical (sparse eddies)...
Maybe, must i change the under relaxation factors for using k-w??
vishyaroon April 27, 2009 16:02
Is your flow encountering massive separation? If not the pressure should not be as sensitive to your turbulence model. Has the solution converged with the k-omega model?
mech5190 April 27, 2009 16:06
have you msn?? for we talk more easy?
