How can define interface between solid and Fluid? |
April 25, 2009, 15:42 |
Saima
Rep Power: 16 |
I have a problem in which a heater is on leading edge of an airfoil and this airfoil is placed in Icing wind tunnel. Air is inside the tunnel at -5C. And water spray by using atomizer is also there. I have to figure out how many water droplet impact on edge. Could you tell me which model should i use? Currently i am using (Eulerian+Discrete phase model). I don't have any clue please guide me. Secondly, how can i define interface between Heater and Fluid(Airfoil wall)? It is very urgent. Many Many thanks in advance. Regards, Saima |
April 29, 2009, 13:03 |
Ralf Schmidt
Rep Power: 17 |
Hi!
you have a solid heater? Than, the interface between heater and fluid is a wall. You have to define it in the mesh generating software. You might also define some existing faces as walls in fluent. When doing so, I would suggest to allocate for each face one separate wall BC - that makes it more easy to difference the different areas when analysing your results. For the first question: I don't know - not a specialist in multiphase flows... Best wishes! Ralf
CFD - nothing but Colourful Fluid Dynamics |
May 1, 2009, 11:13 |
Hossam S. Aly
Rep Power: 17 |
The Discrete Phase Model (DPM) alone should be enough. it is the only model in Fluent that tracks droplets. the eulerian or any other multiphase model will not track the droplet.
May 1, 2009, 21:26 |
Saima
Rep Power: 16 |
Thank you so much for you replies. It really help me alot.
Regards, Saima |
May 2, 2009, 00:31 |
#5 | |
Currently I'm using mixture model (water + air) for my project which dealing with droplets with the diameter of 0.1mm. Basically, my project is on studying the efficiency of mist eliminator system. I'm still not satisfy with my current result as it read zero mass flow rate for water while it got some value for mass flow rate of the mixture. So, I'm looking for another scheme of multiphase model and i really need your help with DPM. My question regarding DPM are
sourplum Last edited by sourplum; May 2, 2009 at 00:53. Reason: change a word |
May 2, 2009, 12:41 |
Saima
Rep Power: 16 |
I want to know ,
1. Is there any technique to calculate the collection efficiency of droplets? 2. How can i define contact angle in DPM (Discrete Phase Molde). I am eagerly waitng for reply. Thank you and Regards, Saima |
May 2, 2009, 13:01 |
Dear Saima,
For ur first question, what i did to calculate the collection efficiency of droplets is by dividing the droplet collected (e.g. Min - Mout) over the mass flow in (Min) and multiply by 100%. efficiency = (Min - Mout)/ Min *100% I can't answer ur second question as I'm not a DPM expert yet. Best regards, sourplum |
May 4, 2009, 00:01 |
Saima
Rep Power: 16 |
Thanks 4 ur reply.
Actually i have an Airfoil and Heater is place on ledaing edge of Airfoil. I have to calculate impingement/collection efficiency on the leading edge. That means how much droplet Impinge on Leading edge. kindly tell me how it's possible in Fluent? Thanks alot... Saima |
May 4, 2009, 00:04 |
#9 |
Saima
Rep Power: 16 |
I have one more question related to the same problem.
1. How can i see the Droplet on leading edge??? I mean flow patteren of droplet. Becoz it is two phase how can i distinguish is it air or water droplet? I am eagrerly waiting for your reply. Thank you saima |
May 4, 2009, 01:55 |
#10 |
I don't think it is possible to see how much droplets have impinge the leading edge. However, u can see the water on the leading edge by displaying the density contour. U can distinguished the two different phase as the density of both phases will be different.
Other idea that come to my mind is by adding inlet and outlet before and after ur airfoil. u can assume the quantity of the droplets that impinge on the leading edge as the nett mass flow of inlet and outlet. Hope these will help. Thanks, sourplum Last edited by sourplum; May 4, 2009 at 03:05. Reason: change a word |
May 5, 2009, 06:09 |
#11 |
Prasad Dudhgaonkar
Rep Power: 17 |
Is the heater is a line or a curved surface on the leading edge of the airfoil? I assume the later is true. I guess you already have exploited DPM sampling by creating surfaces and allowing particles to cross them and collecting data for those particles. I am trying to figure out whether it's possible to deduce the fate of the particle when it impinges upon a particular face (heater in this case). Evaporation is possible depending upon the temperature and heat transferred actually to the droplets impinged/approached the heater. But I am not too sure whether Fluent tells us how many of the escaped or evaporated droplets have impinged on the surface under consideration. I know that I am not able to arrive at exact solution in one go. But in the hindsight I have one suggestion to offer, which is to run the case in unsteady state mode. Using particle sampling you may be in position to judge collection efficiency. This also will help you to actually visualize the flow pattern of the droplets live and arrive at the desired parameters. Best wishes. |
Boundary conditions at Fluid Solid interface (CHT) | michelle | CFX | 1 | April 21, 2008 04:06 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
UDF Scalar Code: HT 1 | Greg Perkins | FLUENT | 8 | October 20, 2000 12:40 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 13, 2000 23:03 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 11, 2000 03:43 |
